Advice on 28" TV purchase please
Discussion in 'TVs' started by Tyke, Jul 31, 2003.
  1. Tyke
    Tyke
    New to the forums so hello folks :p
    Ok am looking to buy, probably from an ebay supplier due to limited budget. Obviously there are a massive number of widescreen 28" boxes out there, but I would rather like to avoid the "lemon" TV's out there.
    Have seen various deals on the likes of LG, Sharp and a few others, but would appreciate some suggestions from you folks "in the know" so to speak.
    Would like to get a TV, DVD and VCR package as I am retiring my old kit to one of my sons.
    I am NOT a hi-fi buff, but do enjoy films and have Cable Digi service. Looking for good clear picture, reasonable sound and to top it all a budget pricetag.
    Lot to ask I know, but your advice would be appreciated (btw probably would have problems accomodating anything > 28" set)
    Thanks in advance for your help :)
  2. phenom2003
    phenom2003
    What sort of budget are you setting aside?
  3. matblack
    matblack
    Jul 30, 2003
    404
    +10
  4. Tyke
    Tyke
    Budget probably in the £4-500 area at the moment.
    Buying through Ebay is no big hassle, I just need to identify what 28" widescreen 16:9 ones I should look out for and what to avoid like the plague.
