Advice on 17" Widescreen choice
Discussion in 'LCD & LED LCD TVs Forum' started by Omertron, Oct 12, 2004.
Tags:
  1. Omertron
    Omertron
    Oct 12, 2004
    162
    Wirral
    +39
    Hi all,
    A relative newbie to the LCD TV market here, but the girlfriend and I have decided to purchase a LCD TV for the 2nd room (Saves kicking the kids of the main telly :rolleyes:).
    We have a budget of around £500 and would like at least a 17" widescreen model. We've narrowed it down to the following two models, but are willing to take alternate suggestions should anyone have any other ideas we may not have considered.... Toshiba 17WL46 or Philips 17PF9945
    Does anyone have any comments? :lease:
    Stuart
  2. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
  3. stuart07970
    stuart07970
    Sep 28, 2004
    2,491
    Slough
    +285
    Buy the Philips! I've got one, its a great set. In the what HiFi reviews of about 6months ago, it took the top-spot, and that was at £900. Its just about to be replaced, so is up for about £450 on unbeatable.co.uk. Everything about it says quality, great picture, great styling, nice remote!
    Lots of connections (but no component!) 2 scarts, sVHS, composite, PC input.
    The Relysis is a great price, but lets face it, it looks cheap!
    Hope this helps
    Stuart
  4. Omertron
    Omertron
    Oct 12, 2004
    162
    Wirral
    +39
    Thanks for that. I think, now that I've had a look at the 17PF9946, that we might well go for that one.
    Stuart
  5. miniboot
    miniboot
    Mar 11, 2002
    10
    I'm also in the market for a tv of this size and price (17-23 ins, £400-£600), can I ask those who recommended it : why would you go for a 17" phillips when a 20" Sharp Aquos is available for the same price?
  6. Omertron
    Omertron
    Oct 12, 2004
    162
    Wirral
    +39
    The 20" Sharp Aquos, afaik, is only 4:3 format and not widescreen.
  7. miniboot
    miniboot
    Mar 11, 2002
    10
  8. Omertron
    Omertron
    Oct 12, 2004
    162
    Wirral
    +39
    The reason, as far as I can see, that the LC22SV2E is so cheap is the fact that the resolution is quite low (854x480) vs the Philips 17PF9946 which is 1280x768.
    Depends on what you want I suppose :cool:
  9. chard
    chard
    Dec 12, 2002
    398
    16
    the LC22SV2E is so cheap because it has been out for quite a while. I bought one 6 months ago when the price dropped to £1100 from nearly £1400.
    If you can find one for £599 then snap it up. I have mine in the bedroom and no problems, it is also a significant upgrade from a 17 " set.
  10. SolarBurn
    SolarBurn
    PC World are selling a KISS 17" widescreen TFT TV for £299 it's a pretty good display for that price
