advice needed
A
aliz
i've researched for ages and i've changed my mind so many times, i was gonna get a jvc, then people tell me they ain't that goog now i'm looking ata panasonic.
what do u think i should get:
the jvcgrdvl367 for £440
or the panasonic nvds30b for £360
the only reason i wont the jvc is for the stills option, but the stills ain't really that good anyway, not worth another £80 for no? and the panasonic has a better review than the jvc, but the jvc has a higher spec. i think i'm trying to get everything on one cam which isn't good. i'm a beginner so i guess all i wont is the highest picture qualilty and dv in/out (i'm gonna get into making my own little movies, i have a high enough spec pc to edit my own stuff)
[email protected]
You can get stills from ANY DV camcorder via the firewire cable.
I use the stop capture feature in Premiere which actually gives better stills than using the still download feature (which uses a serial cable) which came with the capture :)
