Advice needed...
Discussion in 'Plasma TVs Forum' started by AndyBlac, Dec 26, 2006.
  1. AndyBlac
    AndyBlac
    Dec 24, 2001
    40
    Hi Guy's,
    i purchased a TH-42PWD8-BS around this time last year, and it is a fantastic panel :thumbsup: . But i have just purchased the Toshiba HD-E1 dvd player which is hooked up to this plasma through HDMI and it looks great, I was wondering how much better will the TH-50PH9 look apart from the bigger screen size?, would it be worth upgrading my panel to the PH9.
    or if you can recommend another 50" plasma for around the £2400 mark. i was thing about the Pioneer but i have read the it suffers badly from image retention and it does not have a DVI connection.
    Thanks for any advise you can give.
