Advice Needed
Discussion in 'Plasma TVs Forum' started by Se7en77, Apr 14, 2005.
  1. Se7en77
    Se7en77
    I recently had a Philips 37PF9946, which of course I returned.
    Now I'm braving the Plasma world again, and am after a little advice.
    I've been thinking of the Panasonic TH37PW7B.
    I have a surround sound kit, so don't need the speakers, and a Pioneer DVR-420H DVD recorder, so I should be OK with one scart terminal as I can run sky through that.
    So, are they really that good ?? Can you recommend any better for under £2000, or am I better waiting and getting the Panasonic TX32PD50C until the Plasmas are better ??
