Advice needed
Discussion in 'Plasma TVs Forum' started by Z][GGY, Apr 6, 2005.
  1. Z][GGY
    Z][GGY
    Hi all,
    I'm really new to all this and i'm only used to a standard crt tv anyway i'm buying a house and we move in at the start of june and her in doors :) has said i can spend £1,500 on a plasma screen so i need some of the ins and outs plus best screen to get.
    i have bought a jvc TH - V70R as my home cinema system which i'll be using with the said new screen.
    cheers in advance
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Is she strict on the £1500, or could an extra £100 be sneaked in to the budget? You can certainly do something for £1500 that will not have you hang your head in shame, the extra will give you some choice, and some connections. Do you have digital TV? do you mind running the surround for ordinary TV? or do you want one with a TV tuner and speakers built in. They look more minimalist, the designer plasma look without speakers, 'er indoors might prefer that.
  3. superpixel
    superpixel
    I'd prescribe the TV option - a Panasonic TH-42PE50.
    On sale for under £1650 right now, and by June the price should be even more attractive. I can't think of any good reason for you to choose something else, to be honest!
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Apart from the bulk of the thing, and the lack of suitabilty for wall mounting that is.
  5. Anthall
    Anthall
    Oct 27, 2004
    220
    Kettering
    +4
    I would give the TH42PE30 a look. I purchase mine for a touch over
    £3,000.oo including dvd recorder, Cabinet stand and Warrenty some
    Six months ago. Look at the price now, at least a grand cheeper.
    Ive enjoyed my six months though. :)
  6. Z][GGY
    Z][GGY
    well i have been on my knees begging to the lady in doors and my budget will not change.
    the set up will be
    LG RZ - 42PX11 and the JVC TH - V70R
    hopefully this will be o'k
  7. Enquirer
    Enquirer
    £100 over at least the five years you will own the set £25 a year 0.068 pence a day...hope it was worth the saving
  8. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    Enquirer talks much sense...in fact its more like 5p per day....explain to wife about false economies! ;-)....and that you wear the trousers!
  9. Z][GGY
    Z][GGY
    now i do see your points but we have been saving for months and months and we have approx 8 Grand but that is to buy every thing for the house. The good lady only allocated approx 600 for a 32" tv before i convinced her to get a plasma so i think i have done o'k up to know lol.
    So as i would love to spend a tad more i actually have to fill a house :)
    So as i know it is probs not the greatest setup but do you think its an improvement on a 32" setup well i hope so
  10. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    there are happy users here mate....so go for a test drive and let your eyes decide ;-)
  11. Z][GGY
    Z][GGY
    I suppose its the only way really i'll need to get decent scart cables as the jvc TH - V70R does not have componant
  12. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    well dont spend too much....unless you need a long run......
  13. Z][GGY
    Z][GGY
    i saw ones called pure av in argos for approx £20 should these be ok?
  14. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yep...but look for ixos too...
  15. Z][GGY
    Z][GGY
    Will do and hey thanks for your help and advice :)
  16. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    no worries mate :)
  17. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
  18. Z][GGY
    Z][GGY
    Sweet cheers :) i have even found a ps2 to component so i can connect straight to the plasma and the audio going through the JVC for GT4 in 5.1
    Cheers again mate :)
    i know i have a lot to learn but hey your only classed as stupid if you dont ask the question :)
  19. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i only found out the hard way...and digging through these specialist cable / av web sites is a good way of starting to undersand what can be done
  20. Z][GGY
    Z][GGY
    True true also i have printed off alot of the tweaks peeps have used ready for when i get my plasma.
    like i said thanks again mep
  21. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    pleasure...hope it all goes well
