Advice needed
Discussion in 'AV Receivers & Amplifiers' started by The Gooner, Dec 21, 2004.
  1. The Gooner
    The Gooner
    Dec 5, 2004
    1,390
    48
    NE Lincs
    +44
    I have had HC for last 2 years, I have used a basic sony amp and speakers and have npw decided to upgrade. I have just recieved and set up a Denon 2805 amp and Marantz speakers, not sure of model but I know they are same as Marantz hollywood pack speakers, designed by Mourdant Short.
    Im unsure on setting the crossover to get best results. The sub has a crossover setting and the amp has crossover setting, im unsure of how to set these up together to get best results
    Also any other tips ect would be handful
    Thanks in advance
    Goons
  2. The Gooner
    The Gooner
    Dec 5, 2004
    1,390
    48
    NE Lincs
    +44
    please help
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    Not sure I understand, what crossover have you got on your amp?
  4. The Gooner
    The Gooner
    Dec 5, 2004
    1,390
    48
    NE Lincs
    +44
    Its got a crossover frequency for sending noise to Sub (i think) I have at the moment set this to 100 as speakers are rated 100 upwards, therefore my understanding is that all other noise will go to sub as base 100 and below, the Sub also has a crossover setting on it for same thing, as Im not sure how this will work with amp setting I have at the moment set the amp to 100 and the sub to max 150,
    Is this right, I tried LOTR Fellowship ext version in 6.1 DTS, at the begginning I certainly get lots of base through sub during battle, and the ring drops with a nnice thump. But there does seem to be some rumbling is this right.
  5. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    That's correct Gooner, set the sub to the highest crossover and just use the crossover on the amp.
    The amp crossover is where the amp diverts sounds from the main speakers to the amp, the sub crossover will just stop it trying to play sounds above that frequency.
  6. The Gooner
    The Gooner
    Dec 5, 2004
    1,390
    48
    NE Lincs
    +44
    Thanks Bob
    The amp also has a Room EQ settings, Im not sure what this is any ideas?
    I have run the auto set up and let it input its own settings for now.
    Sorry for newbie questions the step up to good gear comes with lots of terminology new to me :blush:
  7. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
  8. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    As Bob said, that is correct - set the sub to max and let your amp handle the crossover.
    The Eq settings are just different modes for you to play around with, just have a look at your manual.
  9. The Gooner
    The Gooner
    Dec 5, 2004
    1,390
    48
    NE Lincs
    +44
    Thanks guys I think a long session of playing is called for, will have to wait whike house is empty again though as everyone moans "its too loud" miserable gits :clap:
  10. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    That's exactly what I end up doing, I always feel like I'm waiting for an empty house...
