Advice needed
Discussion in 'General TV Discussions Forum' started by daver555, Dec 8, 2004.
  1. daver555
    daver555
    Dec 8, 2004
    45
    Sandhurst, Berkshire
    I'm sure this has been posted numerous times before so apologies for adding to the growing list.
    I'm planning on buying a 32" Widescreen before Christmas. I will be mainly using it to watch Sky digital, watching DVD's (lots with DTS) and playing the the old PS2. I have a JVC thv70r home cinema system too.
    I'm thinking of the Panasonic TX32PD30 as suggested by my brother who works at Panasonic HQ in Bracknell. I have funds of around £900 but I'm not overly keen to spend that unless the TV is top notch. I would be happier spending between 600 and 800 so whats the ideal TV for my setup? I am also open to suggestions of a 28" widescreens tv also.
  2. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    You may want to check out the threads on here on the PD30-does your brother not like you?! :)
  3. allengn
    allengn
    Sep 6, 2004
    104
    Sutton Coldfield
    I was going to buy the TX32PD30 until I read the forum thread about all the problems with the set. I agree the picture looked superb in the shop, but I was worried what would happen once I got it home.
    Consequently I started looking around, and finally plumped for the Toshiba 32ZP48. Have a look at the following thread http://www.avforums.com/forums/showthread.php?t=165578 for recent views on this TV. It is currently available, (I think) for around £850, but go and have a look in your local TV superstore. Comet, Curry's and Dixon's all stock the set.
    I've had my set for just over 2 months now, and am well pleased.
  4. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    You have to put these comments in context.
    I was in exactly the same position a few months ago, but my PD30 is excellent and there are plenty of Forum members who think likewise.
    As has been said many times, there's no substitute for doing the legwork yourself and comparing sets in various shops.
    Then, make sure you buy from a dealer with a reputation for good customer service, like John Lewis.
    Good luck. :thumbsup:
  5. red16v
    red16v
    Aug 20, 2004
    552
    +5
    I thoroughly recommend the Toshiba 32ZP48. Regards, yt.
  6. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    I think you've posted that as often as I've recommended JL!
    :laugh: :laugh: :laugh:
  7. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi 'Tight Git' - yes, it could become a 'catch phrase' ! But I do thoroughly recommend it. Regards, yt.
