terryr
Hi Folks
I can’t seem to find a definitive answer to my questions about the harmony hub. Maybe I’m just thick which is more than likely!
I currently have my TV in our lounge and the AV equipment in a comms cabinet in our under-stair cupboard. This is currently controlled by a harmony 950 remote via an IR receiver/extender to which the blasters are connected to the front of each piece of equipment in the under-stair comms cabinet. (HTPC, Yamaha RX-V779, Humax Freesat Box all of which are about to be upgraded but that's irrelevant to my questions)
Firstly, this is an untidy solution as having all the blaster cables on view in the comms cabinet is not ideal as well as the fact that these often fall off.
Secondly, I want to add an NVidia shield tv pro to the comms cabinet and as that needs Bluetooth to control it I am considering adding a harmony hub to the 950 remote.
So a few questions:
1) The hub will be placed in the glass-fronted comms cabinet which is in the under-stair cupboard through two doors (Lounge and Under stair cupboard doors) 15 ft away from the TV. The cabinet has 4 shelves each housing a different piece of AV equipment. Will the hub be able to control the equipment on its own or will I need to use the blaster extension that comes with the product? The hub itself will also be in the cabinet.
2) I note from the harmony site that they suggest that you should have a blaster near your TV so that the hub can control it along with the AV equipment. Does this mean I would have to run the blaster cable from the hub in the under-stair Comms cabinet to the TV in the lounge? All our cabling is hidden and runs between the joists in the ceiling so doing that would be an absolute pain.
Any advice would be appreciated or any ideas about alternative robust solutions would be welcome.
Thanks in advance for any advice.
Terry
So a few questions:
Terry
