Advice Needed Plz
Discussion in 'AV Receivers & Amplifiers' started by felixp, Aug 30, 2005.
  1. felixp
    felixp
    Aug 30, 2005
    55
    Hi I need some help, I am just setting up my first home cinema system and i have mission 702e (front) mission 75c (centre) and mission 700 (rear). I will be using it for both films and music. I like my music crystal clear and not too bassy or trebly. I can get a good 2nd hand deal on either of the following 3 receivers -
    denon avr 1804
    marantz sr5200
    yamaha htr-5540rds
    Which do you recommend and why?
    Thankyou. :lease:
  2. felixp
    felixp
    Aug 30, 2005
    55
    Someone? If it makes things any easier they are all 2nd hand, the denon is £200. the yamahe £80 and the marantz £100. Opinons please
  3. KoThreads
    KoThreads
    Jan 18, 2005
    2,979
    +165
    felixp
    this is of little help but i had a similar setup before i changed speakers, and i couldn't find an amp that had the sound i wanted. i always found the 702e lacking something in the overall sound. Stereo was o.k. but not for movies.
    Your best bet, though tricky in your situation, is to try and hear some amps with them, or it could be a disappointment.
  4. felixp
    felixp
    Aug 30, 2005
    55
    Ok thanks, I'm thinking I will build a decent budget system first, then upgrade as and when. Any more thoughts people?
  5. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    I would recommend you save some money and buy a better newer amp or look at the cambridge audio 540r as they are quite musical (ask chedmaster as he owns one)or a s/h martantz 5400/5500 .
  6. felixp
    felixp
    Aug 30, 2005
    55
    No more advice??
  7. Gary_W
    Gary_W
    Jun 6, 2005
    450
    +21
    I have the Marantz 5200 at the moment.
    Whilst a good enough budget amp, you can certainly do better nowadays. Its bass management facilities are rather lacking (only 1 crossover frequency at 100Hz) so it's not quite as nice to set up a sub as other amps.
    Music performance is pretty good at its price point, though it wasn't as good as the aging Marantz PM66-se (stereo only) that it replaced. I'm afraid I cannot compare it to the other amps mentioned, or indeed to current budget offerings.
    I think I paid around £300 for it from Richer Sounds about 3 years back. Can't be more precise than that. It has done exactly what it said on the tin ever since.
    I'll be upgrading mine in a few months. I've enjoyed it, but it's time to move onwards and upwards :)
    As an aside, I personally will not bother looking at Denon amps. I know it's hardly a scientific survey, but it seems like the vast majority of people posting here with amps breaking down are Denons. And they aren't usually very old either :eek:
    Gary
  8. felixp
    felixp
    Aug 30, 2005
    55
    Thanks gary! The reviews I have read of the marantz all seemed quite good, I know it is an old amp but I havent got a huge budget, i guess it might be that or the yamaha.
  9. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
  10. felixp
    felixp
    Aug 30, 2005
    55
    Thanks for that, the Sony looks really good......
  11. KoThreads
    KoThreads
    Jan 18, 2005
    2,979
    +165
    I'd agree the Sony looks a corker and has better specs (apart from 100wrms x 6) than my 3 year old Kenwood 9060 THX 6.1 that cost me £450
    At that price i'm tempted to go have a listen. I wasn't even considering buying a new receiver.
  12. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    :devil: My work is done :devil:
