Im not sure if this is posted in the correct section, apologies if it is not
Ive been using the old method of recording from sky+hd to dvd-r for ages now, and want to be able to start actually doing some proper hd capturing through my pc, but I am a bit puzzled on a few things, so hopefully someone can help me
Ive been looking at the skystar hd2 pci card, and regarding a few reviews and peoples opinions etc, it looks quite a good 1 to start with, but I may have a problem with set up
I currently have a sky+ hd pace box, but as its over the other side of my room from the pc, I will prob have to get an extension or similar, but theres a problem i need to figure out 1st
I think on the sky hd box the sat cable is connected to the box with a dual cable. Is there any way of splitting 1 of the feeds so I can still run 2 to the sky hd box, and 1 to my pc without having to get another cable installed to the lnb?
Sorry for the long post, I need a bit of help!
