Advice needed please. buyin first plasma
Discussion in 'Plasma TVs Forum' started by LLcoolDave, Oct 28, 2004.
  1. LLcoolDave
    LLcoolDave
    Oct 28, 2004
    132
    Bristol
    +4
    hello people
    im buying a plasma saturday, and have narrowed it down to two.
    it needs to be wall mounted and used everyday as a tv.
    Hitachi 42PD3000 2199.99 from richersounds
    or
    LG RZ42PZ11 1999.99 from currys/dixons
    i have a good home cinema set up already. ive looked into the hitachi and it looks like a good deal. the LG surprised me on a trip to currys as seemed good quality pictures/connections etc, but cant find any reviews on it?
    any advice would be appreciated
    thanks
    dave
  2. quattro
    quattro
    Nov 30, 2003
    389
    Stafford
    +16
    If it a pannel your after you can't go far wrong with a Panasonic PW6/7 as many will tell you here and cheaper than those mentioned.
    Quattro
  3. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    I'll second that. AV-sales will sell you a PW6 (or silver PW7) for the same money (or less!) as you're looking at spending, and panasonic are probably the panel of choice on these forums (for SD viewing)
    ZedZed
  4. grahamtriggs
    grahamtriggs
    Nov 19, 2002
    779
    28
    +33
    The Panny is cheaper than the prices quoted, but those prices are OTT!!!
    The only review of the LG so far is in Digital Home Magazine - the one with "UK'S TOP 10 Plasma TVs" on the front cover. Note that you can get the LG for under £1500 if you have a quick look round the net, or from a major retailer, try Comet's website where it is £1599.
    AFAIK, the 42PD3000 is an old model... current model is 42PD5300, and can be sourced for around £2100 - £2200. It's ALiS technology though, which is a bit of cheat, and doesn't go down well with everyone. You really need to view it first.
    Otherwise, as they say there are the Pannys. Although, do you need a TV tuner? That isn't clear from what you've posted. If you don't, then the PW6/7 panels will be fine - otherwise you would need to step up to the Viera, which is quite a bit more expensive than the other options - especially if you are wall mounting, and so the free cabinet offer isn't so attractive.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    If you have an AV amp with video switching/conversion Denon 3803/any higher end Yammy Pio Denon HK ARCAM in fact almost all then the Panasonic 42PW6/7 from under £1600 + mount is the way i reconmend you go.
  6. LLcoolDave
    LLcoolDave
    Oct 28, 2004
    132
    Bristol
    +4
    thanks for the advice,
    gonna go for the pw6!
    :thumbsup:
    thanks again
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  8. LLcoolDave
    LLcoolDave
    Oct 28, 2004
    132
    Bristol
    +4
    thanks for the advice.
    im gonna go for a panasonic pwd6!!!
    thanks again
    :thumbsup:
