Advice needed on which device to get...
Discussion in 'Mobile Phones Forum' started by earthdan, Sep 4, 2005.
  1. earthdan
    earthdan
    I'd like to buy a device which:
    1. is a phone
    2. I can receive and send e-mail on (in UK and overseas)
    3. I can browse the internet on (in UK and overseas)
    4. will allow me to upload/download e-mails from/to Outlook on my XP desktop with the minimum fuss and maximum control
    5. has a decent sized and good resolution screen
    6. will read all major file formats (Word, Excel, PDF, etc)
    7. can fit in my jeans front pocket
    8. has been on the market for less than nine months
    9. I can use anywhere (I guess within a GPRS area)
    Also, can anyone recommend a provider too? I won't use the device much for calls, so can be on quite a low call tarrif, possibly with a data provision as I'll probably use it more for e-mail/web. Don't want to pay more than about £30 per month. Don't want to pay more than about £150 for the unit itself.
    I really am a novice on this subject, so if anyone can give me any advice, that would be much appreciated. There seems to be so much out there - I can't cope!
    Thanks in advance.
  2. Uridium
    Uridium
    Jan 29, 2005
    14,415
    North West Leicestershire
    +1,855
    Congratulations - You have just described the Orange M500
  3. earthdan
    earthdan
    Thanks Uridium...I'll look into it.
  4. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    Without wishing to hijack the thread, I want a device that supports WLAN so that I can load a Skype client and use Skype when at home. Is the XDAi or s my only option?
  5. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    Londoner living in Doha, Qatar
    +139
    As stated above the Orange M500 or MDAIII in my case is spot on!
    Just a word of warning for you, Skype last time I checked for Windows Mobile did not support voice calls from the PDA device. They said on the web site that they are working on it though! I guess it will be Soon(tm).
  6. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    What's an MDA111?
    I would prefer O2 as I get 30% discount
  7. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    +139
    Exactly the same as the Orange 500 just badged t-mobile. I believe its something like the XDA 2i?
  8. Uridium
    Uridium
    Jan 29, 2005
    14,415
    +1,855
    To clear up the I-Mate/Orange SPV-M/T-Mobile MDA/O2 XDA model confusion that I always read on posts here.
    MDA (Tmobile) is the same as the O2 XDA
    MDAII (Tmobile) is the same as the Orange SPV-M1000 and O2 XDA2
    MDAIII (Tmobile) is the same as the Orange SPV-M2000 and O2 XDA2s and I-Mate PDA2k sim free
    MDA compact (Tmobile) is the same as the Orange SPV-M500, no O2 equivalent in the UK but O2 mini elsewhere in the world or same as I-Mate Jam sim free .
    O2 XDA2i is only available on O2 and is basically the same as the orginal XDAII but with faster CPU/Wireless Lan card and Megapixel cam.
    MDA Pro/XDA Exec /I-Mate JasJar is coming soon
  9. dancingmatt
    dancingmatt
    Apr 26, 2005
    433
    +13
