Advice needed on trying to replace this CCTV camera - what with? based on the cabling?
thecount
My house came with a CCTV system, a series of cameras internally (fake alarm sensors) and some external ones which have a GANZ logo on them, one of which is this one - based on this cabling, what would I be able to easily replace this faulty one which is very bright and looks like its lense has probably gone now, after ten years?
thanks in advance.
D
Deleted member 24354
Hard to advise without knowing what it is connected to
thecount
its all connected to what looks like a unit which has a hard drive in it, with a DVD drive too if that helps? I use HikVision to log in too. the cables going into it look the same as they do on the photo at the other end?
D
Will really need a model number as it will help us understand what cameras bit will support.
