Advice needed on subwoofer upgrade sb1000 or sb2000 pro to go with Min22's
stewjoy
We went through a online chat with the guy he got them from. Setting the subs up with audyssey then setting the audyssey app so it only controlled from 500 hz turned of midrange compression then re ran and checked with a spl to all read 75db then went into svs aop and set them 5 db higher and put in movie mode. On the denon app you can change from reference to flat to off i believe and we kept switching whilst running the same scene and stuck with reference. I hope i have explained this right grammer is not buy best subject sorry
When you put it into Movie mode did you also use the parametric EQ ?.
if so what settings did you use.
DodgeTheViper
Thanks dodge i didnt no that i just took it that it was a dsp mode
The next time you select it, take a look at the volume setting. I think it's a little confusing to begin with were people do think it's actually a 'movie' setting were it isn't in reality.
stewjoy
The MOVIE preset defaults the volume to -10db
When I did my measurements I had to take mine down to -19 to get it to measure, when I have changed to Movie mode it goes to -16.
DodgeTheViper
Pretty much. They're basic presets were you can save your own changes.
DodgeTheViper
Did you already save something in there ?
stewjoy
I may have done, getting a bit confused. It’s just that when I was doing measurements with Arc Genesis I had to take it to -19 to get it to do any sweeps. I may have played with the peq settings. Should I set it back to the default settings.
DodgeTheViper
I wouldn't worry too much tbh. I dont think you've touched any of the other settings so you could just leave it as is.
stewjoy
Thanks Dodge , was hoping that’s what you would say. It can get bloody confusing all this subwoofer stuff. And when you’re an old fart like me even more confusing.
DodgeTheViper
No worries, and yeah it can get confusing. Just ask though ;)
Zigourney
The Apex's got delivered yday. Just set up the front 3.....didnt have to time to calibrate etc. work night and all, first thing that struck me was the size, they are huge for what are supposed to be small speakers. But they do look really nice, even nicer with the grills off. Deep cabinets.
martin 39
Zigourney
How you finding it?
I still haven't had a chance to recalibrate or put up the rear surrounds. But I did re-watch half of Terminator Genesis last night just to give the front speakers a test as I know that movie is quite bass heavy...I left all my existing settings on the avr as per the settings I had on the cambridge audio min22s just for comparison, so basically the crossovers still left them at 150hz for the fronts, 60hz for the centre.
I'm pleased to say they sound great, much fuller sound, a lot more lower mid range was noticeable from the front L/R even though they were still crossed over at 150hz, the top end sparkle from the tweeters were noticebley clearer and had more definition. The center speaker sounded clearer, fuller, and the dialogue sound now covers a wider front space which I think is down to the centre speaker itself being 20cm wider than my previous one. Pleased with it so far...
I need to put up the rear surrounds, recalibrate and watch a couple of movies and play my favourite game call of duty on the new speakers before I can give some proper feedback. Just havent had much time with them yet, waiting for the weekend....almost here now :)
Gasp3621
Brilliant i got mine crossover at 120 which is what i was recommended. Definitely a good upgrade
Why so high? Depending what your receiver founds the roll-off of course, but assuming they are fairly close to walls then i would imagine ported speakers with 5,25" drivers handling 80hz setting fairly easy, 80-100hz would be likely more in the ballpark.
@Zigourney they will sound lot better after doing setup again as you are using wrong settings, too high crossovers and probably correction for old speakers. I would also use higher setting for center channel than 60hz. Most cases there is less reason to keep that low. I hope you would get the center channel at the same level in free air. It so low in depth that you would only need to build small DIY stand for the tv`s feet.
martin 39
I just went with what i was recommended when i got the sub. What happens if its to high i just thought it ment the sub controlled everything
Gasp3621
Do you remember what crossover settings you got for the speakers after running Audussey as i think you bought X4400H? They have been set much lower, perhaps even under 80hz. I`m not necessarily saying 120hz would be too high, but it´s likely the sub also locates bit easier with such setting and the Apex speakers should be able to play lower. I think Monitor Audio recommends 80hz setting for Apex speakers, at least reviews have suggested that and the specs would imply that too especially if the speakers aren´t further away from walls (boundary gain).
martin 39
40hz so i just set that at what my old arcam used to. Good point on the sub i was thinking the sub was easy to locate. Ill give it a try thanks gasp
Gasp3621
Ok try lowering them then from 120hz to 80hz and listen few clips. If you got 40hz for all system then yeah change to 80hz.
Bowers PI7 wireless in-ear headphones review coming soon to AVForums
Latest News
AVForums Podcast: 21st April 2021
  • By Phil Hinton
  • Published
JBL Synthesis SDP-55 processor and SDR-35 AVR now available separately
  • By Andy Bassett
  • Published
Technics launches SL-1200MK7 DJ turntable in silver
  • By Andy Bassett
  • Published
Bowers & Wilkins launch PI7 and PI5 True Wireless headphones
  • By Andy Bassett
  • Published
Technics introduces affordable SL-100C turntable
  • By Andy Bassett
  • Published
