Advice needed on setup
Discussion in 'AV Receivers & Amplifiers' started by saggu1, Jul 19, 2001.
  1. saggu1
    saggu1
    My home cinema kit comprises of:
    Toshiba 3787DB television
    Mission M73's
    Technics speakers from my HiFi for center
    Toshiba L&R surrounds (come with TV)
    Eltax A-10 subwoofer
    Yamaha DSP-AX620 amp
    The sound from the set-up is superb but is there any way I can optimise the reproduction?..I am using QED scarts for the connection of hardware and QED silver spirals to the amp. In addition, I have an optical going from the dvd to the amp.
    :rolleyes: :eek: :rolleyes: :eek: :confused:
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The nest thing to do next would be to get a matching Mission centre, the 78c is probably the best bet, because the 71c is pretty poor in comparison.
    Then change your surround to another speaker from the same range as the fronts (M71's?), and finally make sure that all the channels are balanced properly with an SPl meter, using the built in test tones.
