advice needed on setting up 5.1 speakers
Discussion in 'Home Cinema Speakers' started by mackem1966, Jan 11, 2008.
  1. mackem1966
    mackem1966
    Feb 17, 2007
    36
    Hi everyone
    totally new to this as you'll guess from this question :oops:
    ive just bought a 37 inch hdtv and want 5.1 surround sound speakers.
    when i buy a set do i just connect them to the tv or do i need other equipment such as a receiver ?
    i only want a basic 5.1 set to start with (to keep the wife happy) so any cheap but nice sounding speakers that you know of could you please advise on !
    any help would be most appreciated :lease:
    thanks darren
  2. googlebox99
    googlebox99
    May 5, 2006
    138
    +8
    You need some sort of amplification, so you either need to get a cheaper all-in-one system or a seperate receiver and 5.1 set.
    People will be able to answer better if you give a rough budget.
    Also worth noting if you were looking to get "TrueHD" sound from Bluray or HD DVD, you'll need a reciever that deals with audio over HDMI.
  3. mackem1966
    mackem1966
    Feb 17, 2007
    36
    i was looking at 5.1 speakers on ebuyer which basically went from £14 to around £200.
    all of these had a subwoofer and speakers so does the subwoofer provide the amplification ?
    none of these came with a "Receiver" so i thought this was all that was needed.
    most people who reviewed these speakers seemed to be using them for their computer so can they work on hdtv as well ?
    i need the 5.1 sound purely for sd dvd playback and hdtv programmes.
    im looking to spend under £100 and im not looking for the latest in cutting edge technology just a simple cheap but decent sounding bit of kit if thats possible for the price.
    thanks again for replying to my questions
    Darren
  4. DolbyDan
    DolbyDan
    Sep 17, 2006
    2,103
    Canvey Island
    +265
    Logitech Z 5500
