Advice needed on retrieving S-VHS-C footage
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by pgayler, Jan 3, 2005.
  1. pgayler
    pgayler
    Dec 11, 2002
    30
    Maidenhead, Berkshire
    I have 30 S-VHS-C home movie tapes (approx 45 minutes each) that i want to transfer onto DVD through my dvd-recorder.
    My Panasonic NV-S77 S-VHS-C Camcorder doesn't work anymore, apparently a head problem. I have previously looked at getting the camcorder repaired but they estimated over £400 since it has 4 heads.
    The movies i have recorded on VHS-C i can copy onto dvd using the Cassette adapter that i put in my standard VHS Player, but it won't play my S-VHS-C tapes, even though the adapter says S-VHS ??
    I don't want to send the tapes away since that will cost a fortune.
    If i purchase a S-VHS Video player will i be able to put the S-VHS-C tapes in the cassette adapter and be able to play them ? If so any advice on which one i should buy and where from, as cheap as possible, since only need to recover these tapes.
    Or any advice on getting a cheap S-VHS-C camcorder, bit of a waste though since i already have a digital camcorder, but if its cheap enough it would be worth it to get the footage off.
    Are their any cheap S-VHS-C Camcorder hire places ?, i'm sure i could get them all done in a weekend.
    Or is there any other way (cheap) that i can get the footage off, maybe laptop route ?
    Sorry to ramble, and help would be most appreciated.
  2. Origin
    Origin
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    £67.99 is the cheapest I have found for an S-VHS VCR. This and a few others can be found Here
    Mark.
  4. pgayler
    pgayler
    Dec 11, 2002
    30
    Thanks for the help, looks like the SVHS Video recorder route will work and be the cheapest, unfortunately the cheapest few are out of stock at Hughes
