Advice needed on PWD7. PLEASE.
Discussion in 'Plasma TVs' started by Bonzodogdick, Dec 12, 2004.
  1. Bonzodogdick
    Bonzodogdick
    Dec 1, 2004
    171
    16
    Cloud 9
    :hiya:
    What connection boards / cards do I need?
    Equipment.
    Denon DVD-2910. (Recommend DVI direct to plasma?)
    Marantz SR-4500 AV Amp
    Panasonic standard Sky Digibox.
    Before I order the screen, I could do with some advice on what will give me the best PQ.
    Appreciate your help. :thumbsup:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    JS RGB>VGA for Sky and MAW is the DVi man..... I personally would stick with component perhaps even interlaced....... but thats me!
  3. CarlitoBrigante
    CarlitoBrigante
    I'm in a similar situation myself. I was going to get a component board, as well as the scart board (which comes with it).
    Hornydragon, you mentioned JS RGB>VGA. I've seen this mentioned a few times but am not exactly sure what it does. Any chance you could enlighten me? Thanks
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  5. Hawklan
    Hawklan
    Oct 20, 2001
    6,363
    Essex
    +289
    Sorry to jump in but with the JS RGB>VGA can you then add say a Quattro scart switcher box to the JS RGB>VGA to enable multiple RBG signals
    Many thanks
    RON
  6. CarlitoBrigante
    CarlitoBrigante
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    if you are using the VGA input on the panel already yes, if no no (all panny panels come with 1 15 pin -SUB (VGA) connection as well as terminal board options
    MAny people use the Quinttro idea successful (BOX only works with RGB) so not alll in/outs on Quintrro can be used ( VCR one wont work IIRC)
  8. CarlitoBrigante
    CarlitoBrigante
    Cool. I won't be using the VGA input for anything else, so it shouldn't be a problem.
    I don't think I'll need the Quintro, as I have the Pioneer 501 Amp which has 4 Scart connections and the way I'm using it now is kind of like a scart switcher (I think). Hopefully if this same technique works with the PW7 it should all run smoothly through that.
    Thanks again HD, much appreciated ;)
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    yeah pio amp works great as a scrat RGB switcher
