Advice needed on Optical switching & Co-ax conversion
Discussion in 'Cables & Switches' started by midiman, Jan 17, 2005.
  1. midiman
    midiman
    Jan 8, 2005
    320
    London
    I am currently setting up a Home Cinema system and need som advice on audio connectivty
    I currently have
    LG PX11 42" Plasma
    SKY+
    XBOX
    Bose Lifestyle 25 5.1 surround sound system
    Looking to add DVD recorder ( probably Panasonic E85H)
    The SKY only has an optical out (digital
    XBOX has both Co-ax & Optical
    Anticipated DVD recorder - Optical
    Currently the SKY is connected via the Video input on the Bose (best Guess surround sound emulation) :(
    The XBOX is connected via Co-ax - AWSOMMMEEE :thumbsup:
    The problem I have is that I want to connect all three devices digitaly to get the best from the Bose system which is pretty good.
    The only option I can think of is to buy a 3 to 1 Optical switch and then connect that to a Co-ax to optical converter. This seems somewhat messy and a bit of a fudge :thumbsdow . Does anybody know of a neater solution and have recomendations on equipment to achieve this?
  2. midiman
    midiman
    Jan 8, 2005
    320
    London
    Just asking because I thought I'd seen something that allowed for multiple co-ax/optical ins and digital outs. Cant remember what, where or how much. Anybody ?
  3. midiman
    midiman
    Jan 8, 2005
    320
    London
    Either its the only way, no body knows or no body care's :D
    OK The messy way it is
    Does the quality of the optical cables make any difference? TVCables are doing 1m cables for £3.75. Given that I will need 4 of them, I dont want to spend £30 each on them. I would also purchase the TOSLink Switche for £7.99 frome them. Maplins do an Optical to Coaxial Digital Audio Convertor for £14.99. Would this be a good purchase ?
