Advice needed on new player/recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by cookie666, Sep 10, 2012.
  1. cookie666
    cookie666
    Mar 15, 2010
    38
    9
    I've posted this in another forum but had zilch back thought I'd try this one
    My LG - DRT389H Digital TV DVD Recorder with USB 2.0 Interface has broken and I need to get a replacement it plays R1 discs so will need one that can do that job too
    My question is this can I buy a Blu Ray player that has DVD/RW capabilties do such things exist?
    Or should I look at buying seperate units?
  2. cookie666
    cookie666
    Mar 15, 2010
    38
    9
    Am I posting in the wrong forum?
  3. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,119
    +7,018
    The critical point here is whether you mean strictly 'player'.
    All Bluray drives are backwards compatible with DVD.... so, all Bluray players will also play DVD's.
    Also - all units that have Bluray recordable drives can also record DVD's
    but if you actually do mean you are looking for something that will play Blurays but record DVD's, I think you are out of luck.
    There are hybrids available that have a Bluray drive that will play Blurays and DVD's... but record off air to a hard disc ... if that may be of any use.
    If you are looking for proper Bluray/ DVD recorders have a look at this sticky thread which explains about their general use.
