Advice needed on long cable runs
Discussion in 'Home Cinema Speakers' started by bigphilm, Aug 31, 2003.
  1. bigphilm
    bigphilm
    Oct 23, 2002
    209
    +6
    Hi All
    I am just about to set up my speakers,Eltec Chroma`s, connected to a Marantz Sr5300.The problem is I need the cabling to stretch to 12 metres for the 3 rears.
    I was looking at getting QED Original cables, can these be laid under hardwood flooring and dod you get any quality problems with such a long cable run
    Phil
    :smashin: :smashin:
  2. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    604
    manchester
    No quality problems with cables of that length and yes you can lay them under hardwood flooring.
    I would sugest looking in maplins for electircal cable or some other equivilent copper cabling cause it would cost alot less the the qed and you wont notice the difference in quality at that level.
