advice needed on faulty Vitros
Discussion in 'General TV Discussions Forum' started by adriank, May 14, 2004.
  1. adriank
    adriank
    Finally my new Loewe Vitros has arrived. Unfortunately it's got a yellowish down right corner which can be seen mostly when using the menu (grey background).
    In your opinion, sould I try to service it or get a replacement?
    Any advice appreciated.
    Thank you,
    Adrian
