Right, you lot have been great and you have helped me out no end. I am now down to deciding if the ae500 or the Z2 should get my cash ( I cant see either in use locally) and then the question of how to mount the PJ.
If I go the Ae500 route (which seems the most likliey) then i will ceiling mount to make sure there is plenty of room for ventilation at the rear. I am planning on buying a 16:9 manual screen from DRH and I just want to confrim the mounting height of the PJ.
According to DRH website, the case is 6cm tall and the top border is 45cm. If i plan on the top of the AE500 being 51cm from the screen, will this give me the correct position so that i do not have to use keystone, I have seen bits from the manual but to be honest I keep getitng lost on the maths. I would like to have the PJ nearer the ceiling if possible.....
Dave
Dave
