ADVICE NEEDED ON AVR-200 POWER HYPE & DVD
Discussion in 'AV Receivers & Amplifiers' started by Bu Bear, May 20, 2005.
Tags:
  1. Bu Bear
    Bu Bear
    I would be very grateful for any advice on how to upgrade my ARCAM AVR200 and whether a DV89 is a worthwhile investment (offerred at approx £825).
    I really like the AVR200 but I have to run it near full volume to get any oomph out of my speakers KEF CODA 90's (I will invest in B&W's soon). As I understand it getting a P90 will not increase volume but give the sound more depth and clarity when bi-wiring the speakers. Any suggestions on what I could do to increase the output.
    On the DVD front I'm looking for an ARCAM DVD player and have found some DV89's being offered at £825. Is it worth it or should I wait until the next generation (Blueray/HDDVD) comes along.
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    The AV8 and P7 would give you a lot more volume. ;)
    As for the DV89, £825 is too much. I would expect to pay about £600 for one of those.
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    Have you turned up the separate channel volume levels in the setup menus? Or do you just like to pile drive?:)
