Advice needed - infra-red extenders and SKY+
Discussion in 'Sky Digital TV Forum' started by ucsman, Dec 14, 2004.
  1. ucsman
    ucsman
    Nov 25, 2004
    22
    I plan to hide my SKY+ box and AV equipment into a corner unit behind closed doors (and away from little sticky fingers).
    Whilst I am aware that there are IR extender receivers/modules/emitters to do this, I seem to recall a suggestion that SKY+ handsets dont work with this kit??? Any of you guys out there have any experience/suggestions?
  2. converse120
    converse120
    Mar 10, 2004
    25
    Try www.letsautomate.com, and search on Powermid.
    I've just received, and haven't had chance to try it out yet, the Powermid Dual Power. It only says it doesn't work with hi-frequency remotes like B&O or digital cable boxes. I don't have Sky or Sky+ in a cupbaord, but do have the rest of my gear in there. According to the website, lots of people that bought this also bought Sky+ remotes, so there's a pretty good chance it's going to work.
    HTH.
  3. ucsman
    ucsman
    Nov 25, 2004
    22
    Thanks converse120 - will have a look at the kit on the link.
  4. Techno
    Techno
    Nov 20, 2003
    312
    I have the Digi-eye from Letsautomate, works fine with SKY+
  5. OSM009
    OSM009
    Have you thought about using a TV link? If you can run a coax to the room where your IR is?
    I'm just in the process of moving my box into a kitchen cupboard and coming through the wall with the TV link and mounting it by my amp.
  6. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    After abandoning a video sender installation I got an aerial engineer to do a coaxial from my second Sky box to another TV.
    I don't know about the alternatives but he put in a device called "Triax Digital Link" which couldn't be simpler. Works no problem :smashin:
