Advice needed for village hall projector
Discussion in 'Projectors, Screens & Video Processors' started by glebecs, Mar 13, 2006.
  1. glebecs
    glebecs
    Hello All,
    I have been given the task of providing multimedia in a local village hall,
    I need a screen that will be visible in daytime without closing shutters etc (mainly for broadcast digital TV), the size of the hall is approx 12mx8m with the screen required approx 80" in the centre of an 8m wall.
    Budget is a huge consideration here, can anyone recommend a cost-effective projector + retractable screen that fits the bill (can mount from ceiling beam at any distance from screen)?
    Advice appreciated
    Andy
  2. paulmcp2403
    paulmcp2403
    Mar 29, 2005
    1,366
    +149
    an idea of your budget would be a good starting place....£1000 , £5000 etc...
    Then we will do our best to come up with something :O)
  3. glebecs
    glebecs
    As cheap as possible really, maybe £2000 for projector and screen, if less then all the better, must be able to be used during day though.
  4. JorisS
    JorisS
    Nov 20, 2004
    1,570
    48
    Uppsala, Sweden
    +38
    How about a large ass plasma/LCD?
  5. glebecs
    glebecs
    Problem with Plasma/LCD is that even a 50" will be too small in a hall of this size
