Advice needed for PANASONIC TX32PK25
Discussion in 'General TV Discussions Forum' started by tejpalsihra, Oct 19, 2001.
Tags:
  1. tejpalsihra
    tejpalsihra
    Does anyone know anything about this 32" flatscreen television, I am getting it for £859. Is the picture good? is the sound good? Is there anything else I should know before buying it?
    thanks for reading
    [​IMG]
  2. gvr27
    gvr27
    if you can, you should buy the 32PK20.
    It is getting rave reviews.
    I myself am wondering if I should buy this model. The 32PK20 isn't sold in the netherlands.
    Panasonic advised me to buy the pg serie, because of the motion tech. I can't find any reviews of the 32PG30 either.
    So you see, I'm in the same dilemma as you are.
    Good luck :D
