Advice needed for MP3 Home wireless system..
G
gp2229
I want to set up an unobtrusive sound system which streams my MP3s from a central "server" PC to different rooms using ceiling mounted speakers.
I have used Netgear MP101 streamer to date to stream the sound to an existing hifi system and have the wireless network already in place.
Sound quality is not too critical I am looking for background and occasional use really, no surround sound or audiophile standard required.
I have looked at Sonos solutions which look good but expensive.
Has anyone got any experience here that they would be willing to share?
I am fitting downlighting in the ceiling in the main room so no big deal to fit a couple of high quality ceiling speakers but not sure where to wire them to and where to locate a Sonos control unit to which speakers would attach and which would need power source. Would rather not have to cut wire into the walls, maybe I could have the controller in the room above and the wireless control panel would access it from there?
Any experiences or advice appreciated........
stevos
I currently use a combination of a linkstation running slimserver and squeezeboxes either connected directly to my hifi or utilising computer style powered speakers. Works very well, and since i have used lossless codec also sounds very good through my hifi.
stevos
p.s. probably better to redirect this question to the mp3 section as you are more likely to get a response.
