stephen1000
Hello all,
Firstly I have no/very limited knowledge of installing HD TVs or projectors and would be very grateful for any help or advice you guys or girls can offer me. Thanks in advance.
I am in the process of totally renovating a flat I have just bought. I need advice about which cables I will need to run between a ceiling mounted projector and a sky hd box or virgin box etc. My plan is to have a reasonable sized plasma on the tv wall and then a screen which comes down in front of this when I want to use a projector.
The sky/virgin box will be in one corner of the room within a couple of meters of where the plasma will be. I will mount the projector at the back of the room on the ceiling about 4 meters away. I need to chase the cables for the projector and the TV into a wall and then run them in the celling for the projector. I dont have a clue about which cables I need apart from 2 good quality HDMI cables. I have heard of CAT5 or CAT6? but have no knowledge of these or whether I need them. Also how would I set up the audio to this? as I would like to have surround sound which would need to be able to output sound when watching the projector or the TV, or using a PS3.
I have not decided what projector to get as of yet but will have a budget of between £1500-2000 for everything needed.
The room will need to be plastered very soon and I want to know which cables I should run to the projector. Im assuming that a plasma TV will only require having a power cable and a HDMI cable to be chased into the wall?
If I have asked any really dumb questions please accept my apologies in advance. I would be VERY greatful for any advice or help that anyone can offer me.
