Advice needed - bookshelf speakers + amp for open plan room
Helix Hifi
Helix Hifi
I’ve used external DAC’s with my Node2i before, no delay in the sound.
The Topping uses its own master clock which converts the sound from digital to analog. So if in rare cases should you experience lip sync/delays just turn off the audio clock trim in audio settings on the Bluesound units.
I really doubt you’ll have any issues. And you can always return it.
But try the alternatives you in the end have decided to buy, it may be the best before the Powernode 2i was discussed.
darrenhaken
@darrenhaken, are you still debating what to buy? Have you listed to the Silver speakers?
As of about an hour or two ago I made my decision.
I went and listened to the Cyrus One HD, Audiolab 6000A and the Rega Brio. Tested it with B&W 606s and MA Silver 200s.
I narrowed it down to the Cyrus and the Brio, I enjoyed their sound much more to the Audiolab. The Audiolab sounded very neutral in comparison.
I opted for the Brio as it was cheaper and I'll likely gain very little value from the Cyrus on board DAC given I'll be using a streamer (with DAC). The power of the Cyrus would have been a bonus though.
I'm now stuck trying to decide between a raspberry pi streamer or Bluesound node. Discussing this in another thread!
Costello
Excellent choice. Rega make first-class amplifiers. It will give you a lot of listening pleasure.
darrenhaken
I nearly bought the Cyrus as it has HT like the Audiolab but I decided to stick with the Brio in the end.
It's a tiny little thing, can't say I love the appearance but it's fine. If I told friends it's vintage gear they'd 100% believe me
password1
If you have a subwoofer in the living room, have you considered moving the opticon 6 mk2 into the back room and getting a pair of opticon mk2 LCR for left and right duties in the living room.
darrenhaken
3x Opticon LCR would be a lot of speaker!
I remember researching them when I bought my 6's and I could never find any reviews of them.
darrenhaken
Got the MA Silver 100s home and my OH is not happy with their size, they might need to go back 🤯
Are there other smaller speakers that you'd recommend?
password1
The new 7g Silvers look nice and they might impress her?
How about the Opticon 2 mark 2, they're a lot smaller and less than 200mm wide. There is an open box on offer on ebay.
password1
Yeah the silver 50s but they're not cheap for tiny bookshelf speakers. On paper, they lack the bass so probably not suitable for a large open plan space unless you add a sub.
How about the Oberon 3.. smaller than silver 100 but have a 7 inch woofer.
darrenhaken
Oberon 3 might be a good shout. I will check their dimensions.
I was originally looking at B&W 606s as well. On paper they are smaller than the Silver 100s but not by a large amount. I wonder if it would be enough.
Any thoughts on B&W 607?
password1
All personal preference, some love the way they sound, some don't.. Personally Ive never been a fan of the sound signature of B and w speakers.
Helix Hifi
Sonus Faber Lumina. If you need subwoofers or not is probably a yes.
Warm sound, but over priced. Oberon 3 are fine speakers, go for those.
Me personally if looking for stand mounted speakers would buy the new MA speakers.
I am considering the MA Silver 50, the new series. To put in the room I have my Oberon 5, and add one subwoofer in the corner. :D
darrenhaken
Would you consider the MA Silver 50s then?
Onlythesound
Here’s my latest config: the Concept 20s up one end, the B&W 606s the other. Cosmetically, my OH loves them both. Sonically, I do as well ! 😂
You can get it all in black too. However, listen if you can. …
Helix Hifi
Which dimensions does the top plate has? Height also? Do they accept M6.M8 spikes? Perhaps considering the silver 50.100 speakers. But both are large speakers.
Costello
I’m afraid you’re only going to be able to make the correct decision by actually auditioning some speakers. We can all reel off speakers makes and models but only you can decide what suits you. I would recommend B & W 606 S2 but it’s only a recommendation for an audition. You really need to hear these speakers before buying them. Trust your ears.
Helix Hifi
I think the 606 might look smaller than the MA Silver 100s...thoughts?
If I am not wrong the Concept stands are 200 in depth. With is 13 cm.
So the depth is pretty much covered since the Silver speakers are 30-33 cm in depth. 13 cm wide can perhaps be problems but since @Jester1066 is using Atacama stands, you should be okey.
Perhaps he can say the dimensions on the top plate, and which stands he’s using. Atacama Moseco, Nexus something like that. How much the weight is each with the stands/speakers/Atacama filler.
The Nordstone stands I mentioned have top plate which measures 200, 200 mm, they should be okey.
Helix Hifi
The Silver speakers dimensions are 33 mm depth, 23 mm wide.
So most stands are 15 mm wide, 18-20 mm depth. Because the of the depth of the speakers it might be a problem, still with Blue-Tech you should be fine.
They are of of course 37 mm in height. But they weigh 9 kg each.
The STA 24 weights 7 kg-9 kg each. With Atacama sand filler/play sand perhaps as much as 20 kg each.
I believe even if most stands are the dimensions I am mentioning you’ll be fine.
But I agree with you the Silver 100 are monster!
Latest News
AVForums Movies Podcast: 20th October 2021
  • By Phil Hinton
  • Published
PSB announces M4U 8 MKII wireless headphone
  • By Andy Bassett
  • Published
Melco introduces N50-S38 music library
  • By Andy Bassett
  • Published
Sony expands 360 Reality Audio to Amazon Music Unlimited
  • By Andy Bassett
  • Published
Google launches Pixel 6 and 6 Pro smartphones
  • By Andy Bassett
  • Published
