Advice needed - Arcam AVR100 or Yamaha RXV1000
Discussion in 'AV Receivers & Amplifiers' started by neilybealy, Jul 11, 2001.
Tags:
  1. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
    Can someone please give me their views on the Arcam AVR100 and the Yamaha RXV1000.
    I know the Yam has Dolby EX6.1 but will this really be effective with only 2 rears???
    Neil :cool:
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The Yamaha has a pre-out for the 6th channel where you should connect a monoblock (1 channel power amp) to drive the center rear speaker. If you don't do this then there is no "6.1" sound.
    (The e.g. DSP-AX2 has the amplification for Ex/Es built in.)
    [ 12-07-2001: Message edited by: Reiner ]
  3. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
    Now I understand!!
    Neil
