hellouThere
Hi there,
I move quite a lot so I've always had small all-in-one systems and looking to keep it that way for the next years. All my music is on PC HD and Tidal.
My current setup:
NuPrime IDA-8 + KEF LS50 + PC source
I'm looking to upgrade the amp to something more powerful and then swap the speakers to Magnepans LRS or 0.7.
Now I'm after itnegrated amp (ideally with dac+streamer) or integrated amp and dac+streamer seperate. The budget is $4-5k (excl speakers).
The options I'm considering right now:
1. Nad M33
pros: light, all-in-one, BluOS, high power to drive magies, DIRAC (!)
cons: SQ is apparently 8.5/10, Sabre ES9028 DAC chipset has a mixed reviews
2. Marantz Model 30 + Bluesound Node 2021
pros: I really like marantz sound (had one in the past), A/B amp which has great reviews (didn't hear this one), lots of power, BluOS
cons: 2 pieces, Bluesound has mediocre DAC which might bring the whole system down
3. Marantz Model 40n (coming out right now)
pros: it could be as good (?) as model 30 but with streaming and DAC, all-in-one
cons: less power than model 30: 70W (9ohm)/100W (4ohm) - is that enough to drive Maggies?, ESS ES9016 DAC could be mediocre, HEOS < BluOS
I'd like to optimise for SQ and weight. Any other suggestions? Ideally one-two pieces.
Advice highly appreciated
My current setup:
1. Nad M33
