Advice - need ultra compact 5x optical zoom.
Discussion in 'Photography Forums' started by mutamist, Oct 16, 2005.
  1. mutamist
    mutamist
    Apr 30, 2005
    1,126
    Hitchin
    +88
    I'm after and ultra compact digital camera with 5x optical zoom, good battery life and is small enough to fit in my pocket - I also want a short shutter lag.
    The Pentax Optio SVi seemed to be great until I saw it had a single shot shutter lag of 1.65 seconds which is tortoise like. One that seems pretty good and the only one I can find with all the features is the Hewlett Packard Photosmart R817.
    Any advice would be much appreciated - thanks
    Steve
    EDIT: Just seen two more which sound good: Panasonic Lumix DMC-LZ1/LZ2 with a 6x optical zoom and Samsung Digimax L55W with 4.8x optical zoom - any thoughts?
  2. pbickle
    pbickle
    I was recently considering the Ricoh Caplio R3, which has 7.1x optical zoom. Unfortunately it's a little too new to get any good reviews.
    Perhaps someone else has used it?
  3. longleyc
    longleyc
    The Pana will undoubtedly offer Optical Image Stabilisation (OIS).
    Worth a stop or two over other models.
    Heres the numbers........
    Zoom from Wide to Tele 37 to 222 mm (6 x) 1.8s
    Half-press Lag (0->S1) Wide angle ~0.55s
    Half-press Lag (0->S1) Telephoto ~0.8s
    Half to Full-press Lag (S1->S2) LCD live view <0.1s
    Full-press Lag (0->S2) LCD live view, wide angle ~0.8s
    Off to Shot Taken LCD live view ~3.7s
    Acceptable for a budget camera.
