Advice - Just how hot do the TX-SR875/805 get?
Discussion in 'AV Receivers & Amplifiers' started by dabbler, Feb 11, 2009.
  1. dabbler
    dabbler
    Apr 9, 2005
    769
    Bury Lancs
    +57
    As title states - just how hot do these get under normal use?
    Historically used to Yamaha's that run cool.
    There are some excellent bargain pricies on the TX-SR805/875 and tempted but the question of heat and possible failure putting me off
    Any posts re owners and experience with these models appreciated
    Many Thanks
  2. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    ive recorded the case of mine at 50c before. ive no idea how hot it gets internally and i dont care either - its been 100% reliable since the day i bought it back in july 07.
  3. Member 639844
    Member 639844
    Former Advertiser
    Sep 2, 2007
    14,799
    Lancashire
    +1,182
    mine gets quite hot but its never missed a beat. Looking round the forums Ive not seen a single post of one failing from over heat. Simply put they are designed to run hot, and do just fine. You can buy a 12v triggered fan if you really want.
    On the OSD you can get its temp up, I think from memory ive seen 67 internal temp displayed.
  4. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
    Max very hot day 60c only seen this once (not seen a hot day since:D), average 52-55c..
    The temps are normal for these amps:thumbsup:
  5. SoOPersOniC
    SoOPersOniC
    mine has ample ventilation so is fine. Does get fairly hot though.
    Dont let the horror stories put you off the 875, this is an amazing amp at this price. Also should come with a 3 year warranty anyway.
    Had mine 9 months now and it hasnt given me any trouble, makesure you get one with new firmware.
  6. John7
    John7
    Aug 6, 2004
    2,803
    +971
    In my experience, when listening at lowish/moderate volumes, the amp used to run hot.
    I found that this was mainly caused by the REON video processing circuitry at the back/RH top side of the amp. If the video processing was not used (set video source to "through") the amp runs as cool as any other I've owned.
    As I don't like to run things hot, I used a couple of 120cm PC case fans on top of the case to draw the warm air through and prevent a heat build up - that worked a treat.
  7. thenicklouse
    thenicklouse
    Oct 5, 2007
    379
    +31
    my 805 no hotter than my stereo amps.
    but it does have ventilation.
  8. paulr2006
    paulr2006
    Jun 30, 2007
    9,528
    Nottinghamshire
    +2,506
    As per the other replies; it's not as bad as some say providing it has room to breath & remember it is designed to work in places with really hot climates & they do give a 3 year guarantee, so don't worry :)
  9. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +7
    This was something that originally worried me when I was considering the 906. However, they are designed this way, and even with my Reon processor on, my amp will play at very high levels for hours on end. There is noticeable heat output but this does not affect the performance at all.
  10. dabbler
    dabbler
    Apr 9, 2005
    769
    Bury Lancs
    +57
    Thanks to all who posted replies - guess im off to the shops this weekend.
    All the best to you all.
