Advice in which Canon mount telephoto lense to get
JohnWB
I have a Canon 100D SLR and I would like to get a telephoto zoom without spending more than around £200.
I was thinking of something around 50mm to 250mm but I would consider any other sizes. I am not after the worlds best, just something that will take good pictures and is reliable.
Does anyone have any recommendations (or maybe second hand and where to look)
doug56hl
Canon EF-S 55-250mm £187.07 or 5 equal monthly payments of £37.42 interest free.
canon 8546B002 EF-S 55-250 mm F4-5.6 IS STM Lens for: Amazon.co.uk: Camera & Photo
Reviews
Review of the Canon EF-S 55-250mm f/4-5.6 IS II lens - LENSTESTS
Canon EF-S 55-250mm f/4-5.6 IS Lens Review
Or a 2nd hand Tamron 70-300 VC or Canon EF 70-300 mm f/4-5.6 IS II USM if you can find one within your price budget. Canon 70-200 F4 L would be the best lens but I'd think it unlikely you'ld be able to get a decent 2nd hand one for your budget.
jaymd1970
I have an old Sigma 70-200mm f2.8 but it’s out of your price range. Maybe worth looking for one as it does give excellent results and are built like tanks.
Similar threads
