Advice: go for a speaker package or mix and match the components?
Discussion in 'Home Cinema Speakers' started by GavinH, Sep 30, 2003.
  1. GavinH
    GavinH
    Sep 22, 2003
    122
    16
    Newcastle
    Hey, I am putting together a home cinema system, and currently all I have is the amp, the Sony STR-V555ES. As per a previous thread, I am considering going for the AE Aegis Evo 3b package, but thought I would check people’s opinions on mixing and matching.
    For example, I searched this forum for posts relating to this AE package, and one guy was saying that he couldn’t live with the sub, and the centre speaker was a little weak…
    Do people think it is better to go for a speaker package, or can you put together a better set-up by mixing and matching?
    What other issues are there? For example, will there certain speakers clash with others? If people do think that its worth considering mixing and matching, then does anyone have any suggestions for a budget of around 750 – 800?
    Stereo sound is important.
    Thanks, Gav
  2. nathan_silly
    nathan_silly
    I've mixed & matched speakers... although the front three are matched, but sides & rears are non-matching. Subwoofer matching in non-relevant.
    Try and find the best sounding matching front three speakers. Then look for the best sounding rears & sides- as long as they sound good, with no colour to them (ie harsh, dull sounding) then they'll be fine.
  3. Webbster
    Webbster
    I'd agree- my speakers are matched in pairs but thats it- fronts, rears, centre front and rear and front effects then I have the sub and I get a lot of "hmmm well you should match them blah blah" then I power it all up and they tend to agree. I would like to test the other speakers that go with my sub just to see what a "set" is like though.
    I'm pretty sure that my hearing is so damaged from my set up in general I wouldn't notice the difference anyway...lol.
    My advice would be to demo lots and then go with what you like, it's all about what you want from a system, not the guy in the shop etc!!
  4. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    Whatever system you come up with there will always be someone that can see a problem with it, some real and some perceived.
    The best system is probably five identical speakers but this tends to be impractical unless we are talking small satellites. The next best is five from the same manufacturer's range with similar tonal characteristics. The purists may complain but it's fine for most of us.
    The problem with mix n match is that some speaker manufacturers voice theirs completely different from other manufacturers and if you have an "odd" centre speaker it becomes noticeable when voices or sounds pan across the sound stage.
    It is less of a problem with rears as voices seldom pan from front to back and it is mainly bullets or helicopters.
    If you can, have a listen to the JM Labs Sib & Cub setup or the B&W VM range as well as the Aegis
  5. Webbster
    Webbster
    My next plan is to start upgrading speakers and matching them up with the fronts, personally I don't like satellite speakers, you just don't seem to get as much of "big" sounds from them, if you get what I mean, they're always very detailed but with big speakers you get more envoloped in the sound field....well I think anyway.....
  6. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    You have been listening to the wrong ones. If a good pair of satellites are well integrated with a decent subwoofer the sound is plenty "big" enough. Mine certainly are
  7. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    As most people have said,mixing and matching is often the way with systems,either by accident or design....it can work very well,and should be done by listening to as many sets of speakers as possible,with your own system.
    Be sure to take time and be careful about selecting speakers for something that sounds good in your own home,not necessarily something that sounds exciting in the dealer's showroom.
  8. Webbster
    Webbster
    I'd be happy to have my opinion changed, but it is horses for courses, I'm tempted to get a home demo on the package that goes with my sub just to see but then you have the hassle with wall mounting etc too I guess? Plus I like the visual effect of offensively big speakers lol
    Definately blag a home demo though, not a showroom one as previously mentioned....
  9. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    I've actually ended up using quite small speakers in my house,having an offensively large pair of Linn Keltiks previously,but driven with the correct amps etc,the results are plenty loud enough....as you said,personal preferences...horses for courses.
  10. Webbster
    Webbster
    It's not a 'loud' thing....it's difficult to describe, IMHO I've found that the sat systems I've heard are pin point precise and plenty loud enough, it's just....ahhh, no, it IS too difficult to describe lol. Mind you I've not heard a decent sat system for a good year or so, so I'll stay open minded on this one!!
  11. megson
    megson
    May 13, 2003
    323
    28
    Tipton
    +77
    I have heard the Acoustic Energy Evo 3B speakers on two occasions and in my opinion you will not get another floorstanding package that good at that price.
    I heard them for the second time at the What Hifi show at the weekend and I think they are excellent for the money. Good with films and music.
    Being very critical you could probably get a more dynamic sub but at the end of the day you are paying sub sat prices for a decent floor standing package. Definitely get a demo.
    regards
    Megson
  12. nathan_silly
    nathan_silly
    I have to agree with Webster- I've heard M&K 150 range (and other mid sized satellite speakers), and they do sound good for AV, with lots of detail & attack. But IMO they're just too much- just too forward. OK for a couple of hours max, but I couldn't live with them. I believe using a Lexicon DC-2 and Bryston and Nad poweramps. For music I didn't like the limited bass frequency response of the sats, and asking the subwoofer to handle upto that point.
    My Kef Reference might not have the power or dynamics of the M&K 150, but I can listen to my system loud, and it doesn't go shrill. IMO the M&K's do.
    For music I prefer floorstanders (in a ideal room), with the floorstanders doing a bit more bass reproduction, and the subwoofer less. I found the M&k's being at 80hz and the subwoofer doing 80hz not as good as floorstanders (say 40hz LF corner) with subwoofer set at 40hz.
    I'm currently using floorstanders for AV (set to 80hz) and standmount music speakers. This is only due to my room... if I had the perfect room I'll set the AV speakers to 40hz, and buy another set of floorstanders in another room for the music system.
    Since I can tailer the sound on the AV system, room boom can be reduced... music system cannot- therefore the reason for standmount music speakers, with a subwoofer to compliment.
  13. andymc
    andymc
    Sep 18, 2003
    266
    Bedford
    +15
    Hi mate
    As a starter for my system I bought the Millenium package from Richer Sounds as it was a stupid misprint allowing me to buy Two fronts, a centre and the two HT2 Bi Polar rear speakers for only £69. I only got it to get the rear surrounds which alone would have cost me £79 at the time.
    Since then I have just been blown away by the sound of this set up. I was about to upgrade to the KEF eggs and they just could not get near the sound I was already getting when listening to music.
    I have just changed my amp to a Marantz SR4300 and put some new speaker cables in this weekend and again there is cleaner sound. Why not check out RS and see if they do the AE's as you have a 14 day money back policy so you can listen to each one in your own home until you find the set up that pushes your buttons.
    Hope this helps
    Andy Cuthbert
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    How much are you looking to spend as there are a few lesser known combo's out there that really perform!
  15. Webbster
    Webbster
    Phew! It was starting to echo in here....lol
    You also did a much better job of explaining what I was getting at :laugh: I think the shrill part is getting there- SOME of the systems I've heard you could cut paper with the treble... I think big speakers give a much warmer richer sound if that makes any sense??
  16. GavinH
    GavinH
    Sep 22, 2003
    122
    16
    Newcastle
    Hey guys, thanks for all the comments.
    Incidentally, the living room is 15’ x 13’ and the TV will be in the corner – so this may effect how well larger speakers operate. However, the best advice seems to be to get a home demo…
    My budget for the speakers is around 750 / 800.
    I have demo’d the M&K K5 system before, actually, it was when I was looking for my stereo system, which is the Arcam CD72, Arcam A85 and B&W CDM 1NT’s. I’d like to upgrade the CD player at some point, and I auditioned the A85 teamed up with the P85, and it sounded really nice :) However, that’s a different story.
    As I was demo’ing the stereo system, the K5 system was in the demo room, and I tried it out both in stereo (with the sub) and in full surround too. I was very impressed with the stereo sound as well as the surround. I don’t have much experience in terms of pure “listening”, but I can say that the tiny K5’s sounded crystal clear, and the music sound every bit as good as it does on my CDM 1NT’s. Having said that, the cost of two K5s plus the sub is > the B&W’s.
    Do you think the M&Ks will fill the living room effectively? They have the benefit of a smaller centre and rears, as it might be hard to set up larger ones…
    Of course, they carry a much larger price tag than the 750/800 budget, but if you have to listen to them every day then hey… I could get what I can from the budget and then add another K5 each month :)
    Has anyone experienced shrillness with the K5 system?
    Will my Sony STR-V555ES do a decent job?
    I don’t suppose the M&Ks are too well discounted on-line :)
    Thanks for all the help, Gav
  17. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    The little M&K speakers should fill your room adequately but if that is the route down which you intend to travel I would suggest that you buy a different and more powerful subwoofer .
    Integration of any decent subwoofer with these satellites should be no problem and whilst it is worth paying the extra for the M&K badge on satellites I don't think that applies to their subwoofers.
    That is a subjective opinion obviouslyand others might disagree
  18. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Hi Gavin
    My room is a bit bigger than yours with my tv in the corner.From my own expensive mistakes i would advise against large speakers especially rear ported models.most ported models sound boomy in confined areas that is why i went the m&k route
    . my m&ks easily fill my room and thats on the end of my nad receiver they also sound great in stereo with my svs filling in below 80hz.Save up and go the m&k route you wont be dissapointed.
    Cheers Gonzo.
  19. GavinH
    GavinH
    Sep 22, 2003
    122
    16
    Newcastle
    IanJ, do you have any suggestions for good subs? Obviously if the M&K isn't up to scratch the intention will be to get one that is better. However, I do of course have to consider the price :)
    Gonzo, I think I like your suggestion of saving and going for the M&Ks. Do you have your speakers on stands? If so, which ones, and how much did they cost? With the K5s being small, it is ok to put the rear speakers on wall brackets?
    Also, is it worth using the K4 tripoles for the rears, or do K5s do a good enough job? Similarly, is a K7 much better than a K5 for the centre?
    Are the Evo3s rear ported?
    Cheers, Gav
  20. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    MJ Acoustics Ref 1 is a nice subwoofer that would go well with whatever speakers you selected.
    I don't know about the various K models but the K4 comes with a wall mounting bracket and that is how I have mine.
  21. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Hi Gavin
    The ae are ported speakers.
    At the momement i have my 850s on mission stance and they look really good as the fronts of the 850s are metal silver mesh.
    The three 850s and the k-4s should have been over 2k but managed to get them for 1,623 quid.If you pm me i will tell you who to contact.
    Sorry dont know much about the other k-series but if you do a search on google iam sure you will get plenty of info.
    You could look at getting a secondhand sub like the B&Wasw675 which is a cracking little sub.I sold mine 6 months old for 365 quid.
    Cheers Gonzo.;)
