Huddo
Established Member
Can anyone recommend a USB adaptor for my new PC. The PC will be upstairs and the router (Sky) will be downstairs. Can anyone offer any advice on which product will be the best way to wirelessly connect the PC to the router.
Will I be best to buy a Wireless network card (for installing inside the PC) or a usb adaptor that plugs in externally.
Whichever one is best can you recommend any makes/models.
Thanks in advance.
HUDDO
Thanks in advance.
HUDDO
