GreasyWeasel
Established Member
I am currently in the middle of having my loft converted and will use one of the rooms as a home cinema. I already have my speakers which are Mordaunt Short 500 Selects. The problem I need advice on is the rear speakers (506 Dipoles) are normally wall mounted however since this is a loft conversion I have a sloping ceiling (60 degree slope) which makes the vertical walls very short. On one side of the room the wall is 1m high and the other it is only 70cm high. The room is 16' wide by 18' long (at the longest point, the room is a bit shorter on the left side, 16').
Where and how would you put the rear speakers? Does anyone know of any stands that would take these speakers?
While I'm on the subject does anyone know of any good centre speaker stands since my kit won't be at the front and therefore I won't have anything to put my centre speaker on?
