Advice for soundbar audio needed!
Discussion in 'Home Cinema Buying & Building' started by ThroupMan, Aug 4, 2013.
  1. ThroupMan
    ThroupMan
    Jul 26, 2013
    Hi there, I am new with home theatre etc and could use some advice. I have purchased a soundbar - The panasonic htb20
    Now I have been informed that this system cannot decode DTS master audio hd (or DolbytrueHD) Now a few of my blu rays use this audio ( on PS3 when I press select while playing a blu ray it says the audio in top right corner, a lot of them say DTS HD etc) so what happens when the system cant use that particular audio? Does it just convert it to something else?
    I am really new to this stuff so I would really appreciate a response, thanks!
  2. Gaspode_TWD
    Gaspode_TWD
    Jun 3, 2008
    720
    Thame
    +69
    Yes.
    Usually you can tell the unit (PS3) to output the sound in a format that will be understood.
