Advice for Newb
Discussion in 'Cables & Switches' started by WSB, May 25, 2005.
  1. WSB
    WSB
    Dec 31, 2004
    358
    +7
    Hey,
    I've got a question that someone may be able to help me with...
    I've got a Sony DAV something dvd/amp thing which connects through to my 32" widescreen lcd. I'm just wondering the best way to connect it up to get the best in sound/picture quality. At the moment theres a fairly hefty scart cable (i forget the make) but it was brought at the same time as my amp (homecinemaheaven which has now ceased trading!). Its a simple scart/scart connection but I'm just wondering is there any better way of doing this? The output from the amp is a scart and i havent got much choice in that but my lcd tv has loads of possible inputs. I've already got a dvi/dvi connection from my pc.
    Any help is greatly appreciated.
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    If the only output the DVD player has is a SCART then (as long as its outputting RGB - check the setup menus for this) it's the best you'll get in terms of picture qulaity. I'm not sure what you use for sound (separate speakers or the built in ones on the TV?) so not sure about the sound aspect.
    DVI would give the best possible picture qulaity on your TV, to use this you'd need a DVI/HDMI equipped DVD player which it sounds like yours isn't.
