Advice for my just ordered PANASONIC TH-42PW6 please
Discussion in 'Panasonic TVs Forum' started by cjb1971, Apr 12, 2005.
  1. cjb1971
    cjb1971
    Apr 12, 2005
    52
    Wel after doing quite a bit of research reading different reviews etc etc i have just taken the plunge and ordered one of these displays.
    I will need to connect my sky digi box, Pioneer DCS-424 home cinema and the kids ps2 to it.
    I have seen the RGB to Plasma VGA Converter @£120.00 +Standard VGA lead for RGB to Plasma VGA.@£22.00
    And the Panasonic TY-42TM4ZB RCA plasma video board which i can get hold of pretty cheap.
    will either of these do or will i need both of them?
    Collecting the screen thursday(paid£999.00) so any help would be apreciated-as a newcomer i hope this is the best place to ask-cheers.
    Also im just redecorating so the option with the least wires so i can hide then in the wall would be best!
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i'm not sure the rca board is any use to you....if that is the component board....as you don't have component out on your pioneer do you? The js rgb to vga is a good piece of kit and one option is to get that and a scart splitter like the quintro which your sky box, pioneer and ps2 could plug into and which in turn would plug into the js and so only one cable to screen. But does your pioneer also have the sound inputs for the ps2 and sky?
  3. cjb1971
    cjb1971
    Apr 12, 2005
    52
    yeah its got 2 audio inputs-thanks for the info
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I dont think this board (4 series unit) will fit in a 6 series in fact i am certain it wont.(thats why they are cheap
  5. fatherted
    fatherted
    Mar 6, 2005
    87
    Hampshire
    Different edge connector - so you are correct. I know this because I have a spare 4 series board.
  6. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    781
    Amsterdam
    +15
    Does SCART-VGA by JS give the same, worse or better DVD PQ ?
