MrSpanman
Ok I will admit it, I just joined the forum to ask some questions, and will probably never darken its door again. To be honest I have very little Hifi related experience, although I am technical-ish.
I am going to waffle on a fair bit below, but to cut to the chase I will then ask for anyone else’s experience of the Denon RCD-N10, because TBH I am unsure if the setup and interface is just flaky or I have bought a lemon.
I bought my last Hifi system nearly 30 years ago. A Denon D100 mini system. Over the years I have had a couple of sets of speaker with a pair of Mission 760i’s for the majority of that time. Ffwd 25 years and the CD player block stopped working, I know outrageous, unreliable rubbish!
Got a used replacement, but 5 years on and that too has gone down and not long before that, one of the Mission woofers went intermittent, break in the coil I think as I removed the woofer and the fault is internal to the speaker.
Someone bought me a pair of Q acoustics 3030i’s for Christmas (completely unbidden, she must want something) and with nothing much to drive them I started looking for a suitable mini-system. I wanted it future proof and fancied something with Heos too. I tossed up between the Marantz X 612 and the Denon N10. Denon won on price and my previous experience of how bullet-proof the D100 was.
Got the N10 today, spent @2 hours trying to get it set-up. Initially tried to get it to connect to wired LAN. Connected via the LAN cable that I normally use to connect to my telly and quite happily streams HD Netflix etc, but the N10 said “no connection” whenever I tried to connect.
After a fair few goes it decided to connect, then disconnected by itself. Anyway eventually it connected and held the connection for more than a minute. I turned on Tune-in radio and streamed the first station I came to. It worked for about 30 seconds and then cut out. This happened on the next few stations I tried. I was also suitably unimpressed with the tinny nature of the sound, maybe its just the bit rate of the audio I thought.
Decided to connect via Wifi so disconnected the LAN cable and navigated to the menu to switch off Wired and switch on Wifi. It wouldn’t let me select that option and kept telling me to “disconnect the LAN cable first”, which I had already done. Did a few “IT resets”, i.e. turned it off and on again. No joy, it still thought I had a LAN cable attached. Eventually I RTFM and did a network reset, it forgot about the phantom LAN cable and connected via Wifi ok. Tune-in radio works ok via wireless interface, at least without dropping so far.
Next, the sound. Sound seems very disappointing. I got the rest of the families’ opinion and this ranged from “tinny”, “no bass”, “isn’t the RH speaker of balance, way too loud compared to the left” to “ sounds rubbish, please turn it off, I hate it”.
So does anyone else have a flaky set-up experience with the N10? If so I am guessing it doesn't bode well for either the future longevity of the system, or me growing to like it. Has anyone else failed to get it wired via LAN and what could possibly be wrong on the sound side. Am I expecting too much? Might the 3030i's not play well with the Denon?
I was expecting to be blown away, and I wasn’t the least bit impressed. In fact I would go so far as to say when I turned it off and put my telly back on the sound from its built-in speakers was nicer than from the Denon/Qs. Might I have I been sent a duffer?
I will fiddle with the bass, treble tomorrow and crank it up a bit to see what happens but "you cant polish a turd" as they say. At the moment its going straight back.
Any opinion or advice welcome.
