advice for a newbie
Discussion in 'Hi-Fi Stereo Systems & Separates' started by pilot, Jul 28, 2002.
  1. pilot
    pilot
    I have a pair of KEF Q1's. I want to buy a CD player and an amp which I can use with these. I have a rough budget of £500-£600 for the amp and the cd player. Any recommendations? I just need them for audio and not connecting them to the TV/ DVD.
    cheers.
  2. Joachim
    Joachim
    I would search on the net for a good deal on a Linn Classik. It's a CD, Amp and Radio in one, I've seen them advertised for about £700-£800, but you might find one for £600, if you can't it's probably worth streaching your budget a bit as I rekon the Classik out performe sany seperate CD/Amp in it's price range or even above!!
  3. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Amp: Arcam A65+ with Arcam CD62T cd player OR Amp: Rotel RA02 with Rotel CD02 (I think!) cd player. Both setups will sound fantastic with your Kef's.
  4. pilot
    pilot
    thanks for the advice guys.
    I hadnt thought of the Linn. Always thought it out of my budget, but will investigate.
    What about the NAD C350 amp and the NAD C521i cd player. anyone had any experiences with these?
  5. Gambit
    Gambit
    The NAD stuff sounds great, better than Arcam (in my opinion). Also, try the Marantz PM6010KI/CD6000KI combo. £50 over budget but well worth it- great duo.
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    If you can get the classik within your budget, it is a fantastic bargain, but is a very cultured sound that you shouldnt buy unless you have heard it. At the other end of the spectrum is the marantz stuff suggested, it is a bit bright and harsh but is an exciting listen, then the arcam would probably be my choice, it sits in the middle and is a rollercoaster when you want but can easily play away in the back ground on less active material.
    ad
  7. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Until recently i owned a C350.Very difficult to fault for the price.Negotiate hard with your local RS and you should secure a new one for a shade under £200. :)
  8. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    Arcam Alpha 7SE CD @£249.99
    Arcam Alpha 8R Amplifier @£229.99
    Both @ Richer Sounds.
