Advice for a first timer...
Discussion in 'Home Cinema Buying & Building' started by pt07ahr, Jun 2, 2008.
  1. pt07ahr
    pt07ahr
    Jun 2, 2008
    3
    Hi, im looking into buying myself a 5.1 home cinema system for my bedroom (its a big room :p) I currently have a 26inch finlux lcd tv, which has 2 hdmi ports, and componant and a couple of others im not really that sure about but dont really seem that important.
    I mainly want it for watching films and playing my 360, however im confused about how to connect the 360 up to is as well as a sky box. as the 360 i have does not have the hdmi port, can i use the component cable or do i need something else, for 5.1 surround.
    The tv also has a built in freeview box, will the sound be put in 5.1 on freeview or sky? and finally can anyone recommend me a system for around the £200 mark? sorry for the questions but ive been reading this site for a while and still dont really get it
    Thanks in advance, Alex
  2. lfcmonkey
    lfcmonkey
    Mar 26, 2007
    1,219
    Doncaster
    +105
    You can connect both you 360 and your sky via optical inputs into your 5.1 system. I have the Sony HT-SS1100 which can be picked up for around £200. It's a great system at a good price and has two optical inputs. :thumbsup:
  3. pt07ahr
    pt07ahr
    Jun 2, 2008
    3
    i noticed that you have sky hd in your sig, does the standard sky boxset have an optical out?
  4. pt07ahr
    pt07ahr
    Jun 2, 2008
    3
    oh and thank you :D
  5. lfcmonkey
    lfcmonkey
    Mar 26, 2007
    1,219
    Doncaster
    +105
    I'm pretty sure it does but not 100% What box have you got and whats the model number and i'll try n find out for you.
    Does your tv have optical out???
