Hi all,
Hope some of you can shead some light on this for me.
Want to buy a Sony camcorder from US as they work out so much cheaper than equivalent UK model. Have a number of questions though:
1) PAL/SECAM and NTSC issue. I understand that there is the difference but if my tv/video/dvd etc is NTSC compatible will everything work together? Comments!!
2) Voltage, will unit work on UK power supply?
3) Am I going to come across any problems in the long run if I buy from US (am I going to regret saving a few hundred quid)??
4) If you can think of any other points that I should consider.
I would really appreciate your comments and suggestions.
