Advance AV cable for XBOX
Discussion in 'Xbox Forums' started by monkeyleader, Jan 19, 2004.
  1. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    Im looking for a cable that will allow me to connect my XBOX to a projector and also give me an optical input for DD5.1 I see the official XBOX one is scart only which is no use to me.
    Suggestions ?
    Nigel
  2. JUS
    JUS
    Jan 21, 2003
    3,432
    Plute
    +319
    I have the added problem that the projector is miles away from my amp and xbox. The solution I chose was to buy a scart switch box. That way I have my GC, freeview, Xbox and DC all going into that. A single scart then comes out into a Scart to Component switch box then a 5m component cable runs from that to my PJ.
    If your PJ is near your Xbox then you can buy the US hi def kit...
    http://www.lik-sang.com/info.php?category=83&products_id=1742&
  3. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,022
    Babel Sensurround
    +207
    I Got mine from www.dvdboxoffice.com
    Sorry i don't know how to post a link but if you click on games then x-box it's about third item down $42.95.
    hth
    Adrenochrome.
  4. JUS
    JUS
    Jan 21, 2003
    3,432
    Plute
    +319
    Before you freak. dvdboxoffice is Canadian. So that's Candian dollars :)
  5. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
