Advanaced scart cable
Discussion in 'Nintendo Forums' started by grs, Sep 18, 2004.
  1. grs
    grs
    Aug 29, 2004
    178
    bournemouth
    Hello i am using the advanced scart cable(RGB) for my xbox the picture quality is good but is there anything else better to use on my widescreen.ant help would be cool.
  2. wod
    wod
    Sep 7, 2003
    196
    +3
    yes component cable if you have the input on it but its not very likely unless you got one of them toshiba strata tvs
    apparently the xbox has weak rgb output
  3. broona
    broona
    Aug 26, 2004
    5,623
    Hexham
    +689
    I've got a Monster S-Video cable on mine, gives a fantastic picture. Will be better through my Ixos component on the new TV on Monday though. ;)
