ADSL modem with firewall
Discussion in 'General Chat' started by Dr Diversity, Jun 8, 2005.
  1. Dr Diversity
    Dr Diversity
    I am upgrading to broadband soon. I want to have a modem with four network outputs, built in firewall and possibly wireless output. Any recommendations on what / where to buy or get further advice would be gratefully accepted.
    Do I need a router facility. I am planning to connect 3-4 computers though normally only one.
    Dr D
  2. deanym
    deanym
    May 29, 2004
    1,786
    +141
    Netgear do a four port, wireless router with firewall - its around £100, the wireless card is £40ish.
    I've had absolutely no problems with it, good range and wep enabled.
    I did have a problem however extracting the password I needed from BT to allow another modem to be used. The call centre guy actually stated BT don't allow other modems to be used, but kindly gave me the passwords I needed to configure the new modem (if you've got these from the original installation then it shouldn't be a problem).
  3. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Second the Netgear. Top drawer kit!
    That BT guy is full of crap - without the password, you can't use the Broadband login (on any router) and you own the password. He wasn't doing you a favour, he was being a twit. :thumbsdow
  4. Squiffy
    Squiffy
    May 23, 2002
    9,662
    Ashford, Kent
    +2,815
    Another vote for Netgear here. I think they attracted some flak when their 802.11G kit first came out, but BIOS updates since then have resolved things.
    And I agree that the BT guy was being a twit. They don't care what modems people used as long as they have the relevant UK / EU certification to be used on our phone system. Which they all do....
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
  6. mjn
    mjn
    May 24, 2001
    17,959
    Herts, England
    +4,934
    Question is...why the hell do all new broadband routers seem to be wireless?
    Whats wrong with good old Cat5 cable?
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    The Belkin one that Ched links to for me, very reliable although curiously the default settings cause it to disconnect from the internet after 5 minutes of inactivity, easily fixed though.
    If you can, get PCI wireless cards rather than USB ones as they're far less resource hungry and definitely neater. :)
  8. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    So that users will also buy the wireless card for the p.c./laptop which cost £16-£60. CAT5 leads are about a quid each. ;)
  9. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    john, HOW DO YOU FIX THAT! ITS SO ANNOYING! i didnt even look for an option!
  10. Setenza
    Setenza
    Jun 17, 2002
    3,345
    +226
    I'd recommend the Netgear DG834GT. It's wireless but has a 4 ethernet ports. It's a piece of **** to set up and the firewall also supports a VPN so you can access your home network anywhere if you so wish to.
  11. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Set the Idle Time to zero.
  12. Dr Diversity
    Dr Diversity
    Scan have some made by Sweex. Seem very cheap, are they a badged product? Anyone tried them?
