ADSL Modem/Router/Firewall Recommendations
Discussion in 'Networking & NAS' started by caylem, Sep 7, 2004.
  1. caylem
    caylem
    Oct 23, 2001
    85
    Feels like home to me
    Can anyone recommend a reliable ADSL Modem/router/switch/firewall?
    I will be connecting 2 PCs and 1 xbox, at this point wireless is not essential, but would be nice down the road.
    I was looking at the Netgear DG834 but heard it had probelms with Peer to Peer
    Has anyone had experience with the DG834 or similar products?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I have a Netgear WGR614, works fine, no experience of other Netgear products.
  3. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I've got a number of machines in a peer to peer network including a few wireless devices through a dg834g with no problems, a couple of mates have the same router too, all good.
  4. Fe+
    Fe+
    Apr 29, 2003
    281
    Cheshire
    +5
    I have a 3Com Office Connect 11g Gateway modem wireless router, nice and easy to set up, plus part of the excellent 3Com family.
    £79 and a lappie card bundle delivered :)
    look here
    it is usually cheaper than the netgear
    might be worth searching on price runner, dealtime and www.planetprices.co.uk as there are sometimes better deals / bundles not always advertised on one or the other sites
  5. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    I had 3-Com and went to Netgear DG834G, the absolute best choice IMHO.
    Very easy to configure and with a powerful hardware firewall :smashin:
    Worth the few quid extra.
    Mark.
  6. oreoboy13
    oreoboy13
    It depends what you want to do with it.
    If you are just using it for if its just wired and local file sharing the Netgear will be fine as will a D-Link, Belkin etc.
    However if you get a bit frisky with your p2p i would recommend you get your hands on some Zyxel hardware. Basically the best you can get within reason.
    I generally have a constant 200 ip connections loging into my router for various things including p2p and my netgear and Dlinks kept falling over and needed restarting etc.
    Since i had a Zyxel not a problem, even after an electrical storm that fried my mates netgear settings (in the same building).
